Sponsored by:
Sponsored by: DashLynx
Difficulty in finding fuse for lighter socket for S60
Old 05-14-2010, 05:41 AM
smagad's Avatar
Default Difficulty in finding fuse for lighter socket for S60
SOS. I have problem in locating the fuse for the lighter in the S60. Even the mechanic can't locate. Please help. Tq.
Old 05-15-2010, 10:03 AM
Anjow's Avatar
Should be number 13 in the side of the dashboard.
http://new.volvocars.com/ownersdocs/..._11b.htm#pg186
Old 05-16-2010, 04:23 AM
Mad Matt's Avatar
Not in my '05 S60R. It was the #11 fuse in the fuse box under the dash in not so easy location. You'll need a tq bit to remove the cover though, if in fact it's there.
Each model year had a different fuse layout.
What year is your S60? If it's not the '01 like Anjow mentioned or the '05 like I have. Look here to find the correct online owners manual for your car.
The fuse your looking for is called the "12-volt sockets".
Old 05-16-2010, 08:58 AM
smagad's Avatar
thanks anjow and matt. i check, my year is 2006.
Old 05-16-2010, 11:52 AM
Anjow's Avatar
Won't be the thing I posted then, since that's for 01-04 I think.
Old 05-16-2010, 02:19 PM
Mad Matt's Avatar
Yep, should be #11 under the dash...
http://apps.volvocars.us/ownersdocs/..._11b.htm#pg157
Like i said, you need a tq bit to get the cover off, and being flexible helps.... lol.
Old 06-23-2010, 02:08 PM
Jimbo_Jones's Avatar
Did you have success replacing the fuse for your cigarette lighter socket?
I use the socket to recharge my cellphone on the road. A friend stuck a pen in the socket, and it sparked, a little bit of smoke, and then it won't charge anymore. So I need to check the fuse to see if it is blown.
Old 06-24-2010, 03:01 AM
smagad's Avatar
Yes, I (or rather the mechanic)found the fuse. It is under the steering wheel. Thanks guys!
Old 06-24-2010, 08:45 AM
fusion's Avatar
Congratulations that you have found it!
Old 04-11-2015, 06:03 PM
Rayer's Avatar
2006 S-60 fuse for lighter. Not 11 or 13. I have removed many fuses and can't get outlet to work but know it is the fuse argh!
Old 05-14-2020, 07:25 PM
ChristaS60's Avatar
Default Lighter socket fuse
is
it's the one in the engine compartment oftentimes
Jilali
07-13-2015 01:26 PM
fiey24
04-05-2014 07:10 PM
b26440510
11-04-2011 10:02 PM
njcardsfan
09-27-2010 07:54 AM
Delirious
09-10-2010 03:57 PM
Quick Reply: Difficulty in finding fuse for lighter socket for S60
