Sponsored by:
Sponsored by: DashLynx
Warranty issues 2013 S60
Old 03-23-2015, 09:13 AM
S40 in Fla's Avatar
Default Warranty issues 2013 S60
Hi guys, I'm up to 43,000 miles on my 2013 S60 and I bought it with 32,000 miles on it. Since that time I've had the fuel pump replaced. Are there any other parts I should have looked at before my factory warranty runs out?
Old 03-23-2015, 10:06 AM
ES6T's Avatar
We can't replace a part without a problem, so if you aren't having a problem, there is nothing you can do.
Old 04-18-2015, 04:23 PM
s6013's Avatar
We had our pump replaced too. We have the exact same car as you. There was a bad batch of pumps according to our dealer. We are at 49,400 now and no other problems since.
Old 04-20-2015, 01:29 PM
deep6blue's Avatar
What symptoms did you have to replace the fuel pump?
Old 04-21-2015, 04:15 AM
S40 in Fla's Avatar
My car was experiencing long cranking issues. Not always but more often over night. From like 3-10 seconds.
Old 04-21-2015, 06:12 AM
s6013's Avatar
We had an intermittent long crank. I eventually narrowed it down to when the fuel tank was 1/4 or less full. Turns out the triple valve in the pump was sticking open allowing fuel to drain back to the tank when the car was off.
Old 04-22-2015, 04:18 AM
S40 in Fla's Avatar
The mechanic first tried changing some o-ring that wasn't sealing properly, but the symptoms happened again leading to very low fuel pump pressure.
Me&Shirley
11-05-2011 04:07 PM
safetynut
10-06-2009 08:00 PM
Spartacus
04-23-2009 02:33 PM
s40
12-05-2008 08:32 PM
Quick Reply: Warranty issues 2013 S60
