starter spins but no engine crank
Old Apr 13, 2015 | 09:24 PM
retsnom26's Avatar
Exclamation starter spins but no engine crank
I'm new to the Volvo world. I have a 2001 Volvo s60. Just the other day I went to start the car and it fired right up. Pulled into a gas station. Got back in and when I turned the key all I got was a loud wining of the starter spinning alone without any noise from the engine and no evidence of it cranking at all. After a few more attempts I heard the starter engage fully and the engine fired right up without a problem. Problem is its happening frequently now. I have no problem replacing the starter but my question is, will that fix it? Or is a deeper electrical problem causing this to happen? Thanks in advance for any help
Old Apr 13, 2015 | 10:16 PM
migbro's Avatar
Replacing the starter will very likely fix the problem.
Old Apr 23, 2015 | 01:54 PM
Ebbervonfloyd's Avatar
It sounds to me like the starter drive is defective. It has a one way bearing that is not catching when you engage the starter. You can replace the starter and this should correct the problem, or a cheaper way would be to purchase a new starter drive and install it in your starter. This is the gear assembly that engages the flywheel. It is pretty easy to change.
jollygoodgold
Oct 18, 2013 10:16 AM
Rntsm
Jan 26, 2013 03:44 PM
chrk
Nov 29, 2011 12:25 PM
Edwardhav
Aug 10, 2011 11:26 PM
motors
Mar 26, 2009 07:50 PM
