Antena won't go all the way down
Old 11-03-2013, 09:05 AM
kwatt's Avatar
Default Antena won't go all the way down
I replaced the radio antena to get rid of the groaning noise when it went up and down. The mast was not going down all the way; the last segment stayed up.
I pulled the top nut and turned on the ignition and the antena popped out as expected. I fed the new mast in and shut off the car and the mast pulled down but it only went down part way, leaving the last segment again. I tried this several times with no change.
The only other piece of info I have is; the mast used to work correctly and the radio code needs to be set. I had to pull the battery and I can't locate the radio code right now.
Old 11-03-2013, 03:55 PM
Old 11-03-2013, 09:40 PM
kwatt's Avatar
Thanks rspi. I guess there must be a piece of the old antena in the motor. I'll be looking at that this next week.
Hopefully I get the radio code addressed. I found an item where you can send you r vin info and get the code. I didn;t have the VIN handy at the time. Thanks for hte info.
Newport_j
12-15-2013 10:41 PM
volvolini
10-14-2010 04:55 PM
Ruskya Mafia
09-26-2009 06:47 PM
Modifier
11-17-2008 08:29 AM
dpallen
03-15-2008 03:00 PM
Quick Reply: Antena won't go all the way down
