Blower motor replacement
RE: Blower motor replacement
No.
Knee bolster out under the glove box. Metal cover for SRS off. Now you'll see the back of the fan. A few screws and it's out. Unplug the connectors. Replacein reverse order.
It's a good idea to disconnect the battery for 20 minutes before doing the repair to keep SRS from lighting in the dash. If that happens it's a trip to the dealer to turn that light off.
Also you'll need your radio code.
I don't know how similar it is, but thesixth post in this thread has some pictures from when I changed my blower motor and blower motor resistor in my V70.
https://volvoforums.com/m_62590/mpage_1/key_/tm.htm
I think Tech has said in the past that the blower motor resistor will go bad first and can cause the blower motor to go bad (am I right, Tech?). If so, my post that I referenced above shows that replacement on the V70 as well (which should be similar to the S70).
When mine went, itbecame intermittant. The brushes had eaten so far into the armature, the contactswere onlytouching the brush sides. The motor is mounted horizontily,so if it was contacting the edges on start up, it would rotate and keep going due to rotational vibration. Other times it wouldn't start at all. When I took it out and apllied power, it would start every time, but I was holding it vertically!It was only whenI took it apart, that I discovered the problem. It seems you may be entering this phase. Or, it could be a failing switch contact or wire connection.
