1998 S70 Not starting
It started with the car just stalling while driving. I replaced the fuel pump relay 2 times and it started right back up. 3rd time it stalled nothing worked .Time to get a tow home. The only way I can get 12 volts
on the fuel pump connector is to run a jump wire strait from the battery to # 87 on the pin were the fuel pump relay goes. I tried jumping #15 & #87. I get no 12 volts at the plug for the fuel pump. I changed the fuel pump and the throttle body sensor & the air control valve also. Also ignition switch assembly.
Help
jpirish
91 240 173K
2 98 XC
1 98 S70
Help
jpirish
91 240 173K
2 98 XC
1 98 S70
rideagiant
09-10-2009 07:56 AM
