Engine runs cold, takes forever to heat up & there is a significant cooling leak
Old 12-20-2011, 11:32 AM
MrJARichard's Avatar
Default Engine runs cold, takes forever to heat up & there is a significant cooling leak
Car: 2001 Volvo S80 T6 Excecutive
First problem...
First symptom: Engine takes forever to warm up.
Second sympton: When traveling at highway speeds, the engine runs colder.
Third symptom: When it's cold outside, below 35 F, the engine never warms up, runs very cold.
My guess: Bad thermostat...
Next problem...
Really bad leak, have to refill coolant resovoir every 30/40 miles, getting worse.
Already replaced a hose, and checked the connections.
Seems to be coming from water pump but not sure.
My guess: Bad water pump.
Any insight into these issues/are they related? Thanks!
Old 12-20-2011, 01:23 PM
Edward R's Avatar
Default Istall a new thermostat.
Along with reparing the leaks,running cold probably is caused by a defective thermostat
Old 12-21-2011, 08:21 PM
Do you think that the leak could be from the water pump? I've having to refill the resivoir every day.
Old 12-21-2011, 09:22 PM
lotus4s's Avatar
Yes it can and I'd recommend getting it fixed asap. If the pump bearing goes bad it could easily throw the timing belt...
rcvolvo
02-02-2011 02:58 PM
shamrock777
08-07-2010 09:24 AM
schwalbe181
08-01-2010 09:21 AM
m300slr
11-18-2008 09:02 PM
LunaNegra
03-17-2008 11:09 AM
Quick Reply: Engine runs cold, takes forever to heat up & there is a significant cooling leak
