window wil go down but takes forever to get back up!
Old Jan 31, 2011 | 09:07 AM
rcvolvo's Avatar
Default window wil go down but takes forever to get back up!
I have a 96 850 glt one problem I'm having is the drivers side window will go down but it seems I have to push the center counsel button about a thousand times before it will go back up. All other windows are fine. Anyone have any ideas?
Old Jan 31, 2011 | 08:12 PM
swiftjustice44's Avatar
Well, the widow regulator/ motor that get's used the most is also the one that has the most issues. Your window does better when it isn't fighting gravity. You could pull the door panel and make certain the mounting bolts are tight; they sometimes get loose. While you're there you could spritz some white lithium grease on the regulator mechanism...but the truth is the regulator and/or motor probably are simply worn out.
Old Feb 1, 2011 | 03:57 PM
rcvolvo's Avatar
Swiftjustice thank you for the reply. Let me if you will give you a little more info, I've read most posts on this but my problem seems unique. Nice and smooth going down ,no clicking no falling off track,I have not to this point had to pull the window up manually.If I press enough times,maybe a couple hundred times it will go up but who has the time? I don't know how to trouble shoot the center counsel relay switch. The cost is around $240.00 for the whole unit.
Old Feb 1, 2011 | 05:03 PM
begovic's Avatar
That is a dirty contact. Spray some contact cleaner in that swich and keep pushing button up and down until start working.
Old Feb 1, 2011 | 05:08 PM
Wait...so you're saying 1000 times...I know you're exaggerating but...so you press the up and nothing happens at all and then you press the button x+1 and all of a sudden it runs all the way up normally? Or...each time you press it moves incrementally before stopping and then press the button again and again, each time it moves a bit? If the other windows work flawlessly, it wouldn't stand that there is a relay issue. One relay powers them all, or so I thought. Bad switch? Dirty contacts?
Old Feb 2, 2011 | 07:06 AM
rcvolvo's Avatar
Begovic, thanks for reply. I'll pull the center counsel window module.
Old Feb 2, 2011 | 07:17 AM
rcvolvo's Avatar
Swiftjustice44, window goes up smoothly when the right contact is made. Have you or anyone reading this ever pulled the window module? Begovic thinks it's a dirty contact, I'm assuming if I pull the module and turn it upside down I'll be able to spray contact cleaner into driver side window switch?
Old Feb 2, 2011 | 07:18 AM
Usually you can clean the switch simply by spraying contact cleaner into the switch using the straw on the can. The cleaner gets in the same way the years of soda, etc. did. I wouldn't bother disassembling anything until you give the easy way a shot first.
Old Feb 2, 2011 | 07:24 AM
rcvolvo's Avatar
Right on, I'll try this afternoon and let you guy's know if that work. Thank You!
Old Feb 2, 2011 | 07:36 AM
Just keep in mind that spraying cleaner while the switch is in place is the fast, down and dirty method. It will often dilute the built up crud enough for the switch to operate normally. As the crud has no where to go, it will build up again later and have the same issues. If it does get the switch working again then at your leisure, later, removing the assembly and a thorough cleaning is in order.
Old Feb 2, 2011 | 10:57 AM
nelsonent1's Avatar
I am having the same problem where the window goes up fine but down real slow. I think everyone if forgetting that the rubber in the window track has soft fuzzy material on it. as this wears out, rubber on glass gets sticky. I can assist the motor and the window moves normally. This rules out all the switch and motor functions... they work or don't work. My focus is on the track. When I spray wd-40 in the track up front... the window moves smoothly. I believe that the rubber in the track has no fuzzy, slippery, smooth material left on it and the glass sticks to it. Until I remove the rubber inside the door, I won't know if I am correct on my assumption. Grease on the track would really make a mess an give dirt something to stick to... so for now... slow down and fast up for my window.
Old Feb 2, 2011 | 02:58 PM
rcvolvo's Avatar
Holy crap! You guy's hit the nail on the head. I sprayed contact cleaner right into the switch and after switching on/off a couple of times I started the car and it works like new! You gotta love this forum, First thread and I saved a ton of time and money. Thanks again!
jscharts@yahoo.com
2001-2013 model year V70
Apr 11, 2014 02:56 PM
mystveous
Sep 13, 2013 12:55 AM
spankey
Dec 14, 2012 01:25 PM
m300slr
Nov 18, 2008 09:02 PM
