Fan/ blower motor stays on
Old 05-02-2011, 07:27 PM
Chassis's Avatar
Default Fan/ blower motor stays on
02 S80 picked up a couple of weeks ago. Anyway the fan/ happened to be the ac came back on full blast after ther car had been tunrned off for about 1/2 hour. Had to turn the key on and turn the fan hi/low switch all the way off the turned the key back off. The very next day, before shutting the car off I turned the fan switch all the way off before turning the key off. It happened again.......... I'm at a lost is this going to be a dealer fix ? has anyone heard of this before and what fixed it? Thanks for reading. I also posted about an immobilizer message and suggestions there? I dont want to start dumping alot of $$ here.
Thanks for reading guy's
Old 05-03-2011, 08:03 AM
jdp6000's Avatar
Its suppose to do that. The fan will turn on every so often to circulate air in the cabin. Next time wait and see if it goes off after a bit.
Jim
Old 06-23-2011, 09:46 AM
contsi's Avatar
Jim
Is there a way to disable this feature so the battery won't drain?
Old 06-26-2011, 06:16 PM
howardr's Avatar
I have an 02 S80 T6 that behaves the same way. And the response I got was the same as you did. But mine will stay on forever if I don't turn the key, same as you.
Question: have you done anything electrical lately...like replace the battery? I believe that there is some kind of battery re-set protocol. Some of the other guys here may know what I am talking about. I have to look it up because my car is doing it alot lately.
Florida Summer...wooohooo!
bobb4503
12-10-2011 09:59 AM
rofuth
05-13-2010 09:09 PM
vince65pr1
06-04-2009 02:53 PM
luke8_8
03-28-2009 02:27 PM
Quick Reply: Fan/ blower motor stays on
