heater/ac fan stays on.
Old May 3, 2010 | 11:41 AM
rofuth's Avatar
Default heater/ac fan stays on.
Hi, I'm new to the forum and was hoping someone has experienced this before. Last night an hour after driving the 2001 v70 I was told the interior fan was still running. As you would expect, all of the display was off because the ignition was off and car was not running but the interior fan was running on high. I pushed several control buttons in attempt to shut it off but the only thing that worked was to insert key, start car and immediatly the fan shut off and then i shut off car and everything went back to normal. My concern is if I hadn't been notified that this was running, I would have had a dead battery by morning. Does this sound like a sticky relay and if so where would that be. I would appreciate any help especially if this has happened to you and you have corrected it. thank you in advance. We love the car for it's comfort and saftey. It has 133k and just purchased it.
Old May 4, 2010 | 07:19 AM
Georgeandkira's Avatar
Default Blower stays on
Hello, The A/C, and I assume ACC systems, have a feature where the fan stays on to blow the evaperator dry. I haven't been able to establish a pattern of this operation in my car yet, a 2002 V70 base. We did just go through a hot spell and at one point the fan was on when I returned to my car. This was after driving with the A/C on AND with leaving the fan control **** at some point in the middle of it's range. It had been running for an hour (I assume it hadn't shut off and restarted). The next day I turned the A/C compressor off 2 miles before I reached my destination and ran the fan on high (to dry the system). I turned the fan off before I turned the engine off. The fan wasn't on when I returned to the car after 10 minutes. I don't know if there is an adjustable time for this feature. I don't remember reading anything about it in the owner's manual. I'll check that today and post back if the subject is referred to. Kira ps What year and trim level is your car? K
Old May 5, 2010 | 05:02 AM
rofuth's Avatar
Thanks for the reply. Our Model is 2001 v70 t5. That is good to know although surprising that it would run that long. I will try to turn off before shut off car. how long does yours run before it shuts off? thanks rob
Old May 12, 2010 | 10:00 AM
Default Days later
Hello, I was doing some underhood cleaning when the vent blower started up. This was after the engine had been stopped 15 minutes. I turned the fan speed control to 0 after about 5 minutes so I don't know how long it would have run. I forgot to check the owner's manual. Any "data" at your end? Ha-Ha Kira
Old May 12, 2010 | 09:17 PM
It will usually only run for about 15 minutes.
Old May 13, 2010 | 04:35 AM
rofuth's Avatar
I have not found mine running since. I'm glad to hear that is normal. thanks for your post.
Old May 13, 2010 | 09:07 PM
JTapper's Avatar
It's set to run for 5 minutes, 50 minutes after you turn off the car.
Old May 13, 2010 | 09:09 PM
It depends on what it is programmed for. It can run for up to 15 minutes.
davemrg
May 24, 2015 08:37 PM
Chassis
Jun 26, 2011 06:16 PM
adi
Jun 2, 2010 12:42 PM
vince65pr1
Jun 4, 2009 02:53 PM
