radio removal
radio removal
I'm trying to install satelite radio modulator and thru this forum have found clues and pictures but I still can't get the radio out! Shift cover is off, AC control I can tilt but it won't slide down or out. Seems to be securly attached to bottom of radio by stiff metal band? Any more help out there? Thanks
RE: radio removal
Check out this site. http://www.carstereohelp.com/stereoremovalVolvoS80.htm
I bought a tool called an apolstery (sp?) remover. It helped me pop off the plate around the gear shift.
Things to watch for:
The screws get lost easily if you drop them.
Remove the fader ***** before removing the face plate. I lost 1 of them.
-hgov
-hgov
