SRS airbag service urgent
Old 06-25-2015, 05:13 AM
ES6T's Avatar
Go to a shop before you blow something up. You should never measure the resistance of an airbag
Originally Posted by tmounib
Help. Help, and more help
Hi everyone,
I am about to go crazy because of my 2002 S60 SRS Airbag light issue,
I have tracked my SRS system and scanned it several times, this does not matter, the crazy part is as follow:::: I disconnected the SRS control box, and with the right DIAGRAM I measured every Airbag resistance and all of them were reading OPEN OHMS except only one. (LEFT FRONT SIDE AIRBAG) The crazy part is:::::: The scanner is saying THE LEFT FRONT SIDE AIRBAG is open (reading too high) So home come the only airbag that is giving me resistance reading (3OHMS) is the one the scanner says is bad????
I am not sure where to go from here.. any idea? any advise would be appreciated.
Thank you all
  #42
Old 06-26-2015, 05:19 PM
tmounib's Avatar
I was looking for TECHNICAL help, not financial advise. Whoever you are ,
Good day
  #43
Old 06-28-2015, 08:09 AM
ES6T's Avatar
You asked for "any advise" and that was technical help. You should never measure the resistance of an airbag. You risk deploying it.
Good luck.
  #44
Old 07-07-2015, 04:18 PM
tmounib's Avatar
No VOLVO dealer service ever again.
My 2002 S60 sat in my back yard for about a year or so, when I put it back on the road I noticed the SRS light and the warning light is on, I took to local shop to scan the system and it was (SIDE AIRBAG SIPS module) we reset it several time but we could not get rid of the warning, anyway I took it to the dealer which equated me for $1100 to replace the module and the under the seat parts + reprogram the system, damn dealer , I called VOLVO corporation to see if they can ((TECHNICALLY)) explain the sudden death of unused car part. anyway I found out the most shocking and unreal facts ever.
1- Volvo dealers are 100% independent and no control over them by the mother company. meaning if the dealer want to charge you $100 for a part that might be $5.00 at another dealer !!!!!! they can , VOLVO have no say .
2- If the dealer screw up your car VOLVO can't do anything about it, it is between you and the dealer.
3-The dealer have all rights to reject or accept repairing any volvo car they feel like,, again The mother company can't open it's mouth.
After I driven Volvo for many many years ,, I think I will never buy another Volvo knowing that there are no SUPPORT once it is out of warranty.
Now I have to say one final word, I do appreciate Ford, Chrysler and GM for the wonderful service they provide for there products and standing behind it with bride,
God Bless our country and damn you VOLVO
  #45
Old 07-19-2015, 01:51 AM
Cade_27's Avatar
Maybe think about buying the 2014D Vida Dice Diagnostic scanner .. With that you should be able to install whatever software updates you'll need along with diagnosing trouble codes and trouble shooting problems that may arise
  #46
Old 07-24-2015, 07:04 PM
div4scpro's Avatar
2009 S60 US version if that makes a difference.
CADE_27. can you or anyone else recommend where to get VIDA/DICE scanner that is not a piece of far east crap or that doesn't cost thousands of dollars? If no such exists then so be it. I have the exact same passenger airbag off issue that occured after Volvo's wonderful interior fan recirculate after you turn the car off drained my battery completely.
Thanks
  #47
Old 04-11-2016, 05:39 PM
maurinquina's Avatar
Dated thread but I had the same issue with SRS AIRBAG SERVICE URGENT just yesterday (April 9th 2016). I used a AUTEL AL619 which I had bought for a 2002 Mercedes S430 last year but never used. Came handy now. I just bought this 2006 XC70 last week and didn't even get it inspected yet. Anyone around NY 11354 needing help . . . . message me.
  #48
Old 04-23-2016, 10:03 AM
V70M56's Avatar
Default AutelAL619
Just purchased a new AutelAL619 based on your advice. Unfortunately the 619 does not support volvo under SrsAbs module, specifically says it does in the manual but it does not, checked the unit online at Autel.com and software is up to date. Are you sure your Autel is not an AL619EU model? My vehicle is a 2004 V70 Canadian car with "airbag service urgent" on display.
  #49
Old 04-24-2016, 06:54 PM
I have a 2006 XC70 and it worked perfectly. DON'T put in VIN but enter info manually by choosing year, model, engine etc. I tried a few times by letting the AUTEL check the VIN but even though it detected the VIN successfully it wouldn't get into the diagnostic mode for the ABS/SRS on my car saying that this function wasn't supported just as you mentioned. Then I entered the vehicle info manually and VOILA ! SRS code found and it asked if I wanted to delete and I clicked YES and it was gone. I have a AUTEL AL619 not AL619EU. I've attached pix of the box for my AUTEL. Checkmark on AL619. Let me know if you need more help. We can go thru it by phone step by step. I'll run the AUTEL on my end connected to XC70.
Attached Thumbnails  SRS airbag service urgent-dscn1002.jpg    SRS airbag service urgent-dscn1008.jpg
  #50
Old 04-29-2016, 06:31 PM
V70M56's Avatar
Default AUTEL AL619 worked!
Thank you for your advice. I did need to update the microSD card (came with the 619) on the Autel website. About 50Mb download to update. Srs codes read and erased using auto VIN finder with Autel 619, no need to input manually. Again my car is 2004 Volvo V70 2.4L non turbo M56 man trans. Thank you!👍
  #51
Old 04-30-2016, 12:14 PM
I hear if you dis connect the negative whenergy you connect the Battery again to have the key in the on II position (second position) to have the SRS NOT come on. Otherwise it's always supposed to.
  #52
Old 09-21-2017, 12:52 PM
paflyboy55's Avatar
I know this is an old thread but it came up when I did a Google search on "SRS airbag service urgent".
I had the same problem when I removed the center console to replace some lights, and of course didn't disconnect the neg side of the battery.
Luckily I stopped at a local shop that does a lot of foreign car work. He has a snap-on scanner and was able to clear the message. Charged me $10. Thought that was a steal.
  #53
Old 11-29-2017, 03:04 PM
jon92117@gmail.com's Avatar
Default SRS airbag service urgent
When you disconnect the radio this will happen. It has nothing to do with disconnecting the battery. My Volvo mechanic showed me the schematic of the warning lights. The radio is in line with the airbags. So when the radio is disconnected, the computer freaks out and sends this warning. Buy a code reader and erase the code and you should be good to go.
  #54
Old 12-06-2017, 12:34 AM
kenchrik's Avatar
Thank you for your advice. I did need to update the microSD card (came with the 619) on the Autel website. About 50Mb download to update. Srs codes read and erased using auto VIN finder with Autel 619, no need to input manually. Again my car is 2004 Volvo V70 2.4L non turbo M56 man trans. Thank you!��
Hey, would you like to share your personal experience about Autel al619 obd2 scanner. What are its pros and cons? I am thinking to buy this scanner tool.
update: just bought
Amazon Amazon
this scanner.
  #55
Old 04-03-2019, 08:32 AM
Larry Beria's Avatar
Anyone with the SRS Airbag service urgent problem, just follow this guide. Explains every possible problem and how to reset the light youreslf.
https://www.youcanic.com/guide/volvo...service-urgent
  #56
Old 04-22-2019, 01:31 AM
sirui's Avatar
Here is a link to get the tool to clear your SRS Urgent Warning light..it is come from autel
They have a scanner here to cover almost every VOLVO out there...
https://www.obdprice.com/collections...nal-scan-tools
crosby1
02-20-2015 08:44 AM
crosby1
12-29-2010 11:02 AM
smithpaw
05-02-2010 10:05 PM
akorcovelos
09-16-2008 02:27 PM
850man
11-08-2007 09:37 AM
Quick Reply: SRS airbag service urgent
