1997 S90 anti theft and a dead battery
Old 06-10-2011, 04:57 PM
badbuik's Avatar
Default 1997 S90 anti theft and a dead battery
My sons 1997 Volvo S90 has been parked due to a possible blown head gasket, I went out to start it and move it a few feet, (it ran when I parked it), but the battery seemed dead, I unlocked the door and the horn started blasting and the signal lights were flashing. I disconnected the battery and continued charging it, hooked it back up, same thing. I took out the battery and will finish charging it on the bench, it shows 12 volts on a multimeter.. How do I bypass what seems to be an anti theft system?? My son just has the key, the remote entry unit died along time ago. Any ideas?? The manual says the radio has an anti theft code, does that kill the start function too?? And where would I find that code??
Thanks in advance.
Gary G.
Old 06-10-2011, 09:33 PM
Lock and unlock the door with the key.
Old 06-10-2011, 11:58 PM
badbuik's Avatar
Well, I went back out and unlocked the car, opened up the fuse box and found and pulled a 10A fuse for the alarm, put the recharged battery back in and it fired right up.
Gary G.
Old 06-11-2011, 02:53 PM
So, did you reinstall the fuse and try it with the alarm system fuse installed?
Old 06-13-2011, 12:15 AM
badbuik's Avatar
I did what you said after I put the fuse in. Not sure why it worked before that, but you were right locking and unlocking the door, with the key, cleared it. Thanks again.
Gary G.
Old 06-14-2011, 09:19 PM
Cool. That alarm situation with dead batteries and replacing batteries throws people a lot.
Old 08-15-2020, 07:13 PM
James Sizemore's Avatar
Default 1999 Volvo anti theft
put new battery in now no start
Old 08-15-2020, 08:58 PM
Ok how do I reset to get my car to start
kellslax
12-20-2010 11:18 PM
lsmith49
09-10-2009 10:03 PM
niccimblack
12-30-2007 05:59 PM
mycarl
02-16-2005 05:47 PM
jayb
08-27-2004 09:29 PM
Quick Reply: 1997 S90 anti theft and a dead battery
