new brake pads and pedal a bit soft
Old 10-05-2009, 10:01 PM
ecberr's Avatar
Default new brake pads and pedal a bit soft
hello all, i replaced the brakepads in my 2000 v70 xc and noticed the brake fluid level has risen in the reservoir. it is right on the max line. also, the brake pedal needs to be depressed about 50 percent before they noticeably work.do i need to bleed the calipers?
Old 10-08-2009, 04:54 PM
VTBricked's Avatar
No, you don't need to bleed the calipers. The pedal is soft and the level higher because you compressed the piston to fit the new (thicker) pads. Push the pedal several times to move the piston out and press the pads against the rotors. After a few pumps, the pedal should be fine.
jgoodiso
09-19-2012 02:48 PM
stormy76
08-19-2011 09:10 PM
cruzcountryxc70
Engine & Internal
04-28-2008 05:42 PM
xc90guy
04-02-2008 10:28 AM
hosey82
08-01-2007 07:40 PM
Quick Reply: new brake pads and pedal a bit soft
