2000 V70XC Won't Go Into Gear. Help?
Old Oct 27, 2012 | 08:32 PM
Lamacchia's Avatar
Default 2000 V70XC Won't Go Into Gear. Help?
So tonight, I was pulling out of the driveway in reverse and there was a loud "clunk" and the car stopped. I tried to keep reversing but it wouldn't move. It felt like the E-brake was on, but it wasn't. I put the car in Drive and it moved forward, but again felt as though the E-brake was on, or the car was in first. I pulled a quick U-turn and pulled back into the driveway.
Long story short: reverse won't work, the car moves forward, but not like it should, and - most troubling - the car won't roll freely in neutral. I can't even have it towed because I don't want to drag it up onto the rollback.
This doesn't seem like a transmission issue, because the car was behaving normally two hours earlier and there has been no slippage. It was just flushed 500 miles ago.
I'm stumped. Thoughts?
Old Oct 29, 2012 | 12:51 AM
Willvo's Avatar
The sudden nature of it is puzzling - even more puzzling is that it won't roll in neutral. It almost sounds like there may be a problem with the electronics or the gear selector, or it may not be transmission at all - could one or more of the brakes have jammed on?
Might be a bit obvious, but have you checked the fuses? Are there any warning lights?
Old Oct 29, 2012 | 07:15 AM
Chances are that you have a CV axle problem.
Jack the car and see if the back wheels spin. If not, the parking brake cable broke.
Lamacchia
1998-2000 model year XC70
Oct 28, 2012 07:50 PM
Auctionguy1972
May 12, 2011 05:29 PM
netscarf
Apr 4, 2009 09:47 PM
89240DL
Mar 15, 2009 10:32 PM
Vee
Jan 13, 2009 06:05 PM
