99 v70 awd under dash problems
Old Nov 26, 2022 | 08:20 AM
99v70awdcolorado's Avatar
Default 99 v70 awd under dash problems
Recently was gifted a Volvo in good shape only issue is the head lights an blinkers require you to hit the under or top dash to come on it’s said that someone broke in an was trying to hot wire it an had no clue what they were doing so everything is loose an a mess
I’m in need of fixing this asap if anyone has any tips or tricks to help get this driving safe again thank you
Old Nov 26, 2022 | 09:12 AM
2 common problems - the electrical portion of the ignition switch melts internally - if your lights, blinkers and heater fan are not working after starting the car - turn the key back toward off a few degrees to see if that helps. If so - replace the ignition switch.
Or - If it's just the headlamps - the headlamp switch breaks and partially falls apart - the headlamps switch simply pulls straight out for removal - but if you do it might/will come apart - so have in mind where you will be getting a replacement.
lotusing
1998-2000 model year V70
Oct 10, 2014 03:40 PM
artistnan
May 10, 2010 08:43 PM
TheTrainwreck
Mar 12, 2010 10:28 AM
rover62
Apr 4, 2008 01:03 AM
Tacket
Nov 24, 2006 10:57 AM
