Axle halfshaft won't seat all the way in
Old Sep 4, 2017 | 04:07 PM
Eddystone's Avatar
Default Axle halfshaft won't seat all the way in
Anyone out there live? My driver side axle on my 98 V70 doesn't seem to be going all the way in. I need about another inch to get my lower control arm lined up. Currently, I have EVERYTHING disconnected from the hub and rotor except the strut and the axle, and the axle is the only thing holding the control arm away from the car.
My car is apart in a place where I can't leave it, so immediate response would be appreciated.
Old Sep 5, 2017 | 07:26 AM
tryingbe's Avatar
There is a c clip at the end of the axle, I found it sometimes easier to get some weight on the axle to help pushing it in, like using the knuckle.
Old Dec 18, 2017 | 12:49 PM
danielak0328's Avatar
If you replaced your axel shaft with a aftermarket (new) shaft, the splines on the shaft may not be correct. (I had the same issue...and had to revert to a Volvo Re-manufactured to get the correct splines to fit the transmission. Went through 3 different shafts before one would fit.)
tycoon
Jun 23, 2016 10:25 AM
Lilys240
Mar 14, 2016 12:02 AM
kwatt
Nov 3, 2013 09:40 PM
Modifier
Nov 17, 2008 08:29 AM
