Locking problems
Old Jul 6, 2022 | 05:56 AM
jcolder70's Avatar
Default Locking problems
Hi
Got a warning light on the dash, saying that the driver door is not shut, having checked the door is shut bu tthe warning is not going off.
Also when using the remote key, its not opening all the doors, it will open the passenger side doors but not the driver side.
When then trying to lock the doors the remote isn't locking any doors.
Any help greatly appreciated.
Thanks
Jason
Old Jul 22, 2022 | 01:53 AM
s10lowrider1994's Avatar
Mine did this and I ended up needing to clean all of the actuators to remedy it.
Old Jul 22, 2022 | 08:10 AM
Dingus1's Avatar
Originally Posted by jcolder70
Hi
Thanks
Jason
Also, your doors aren't locking because it thinks a door is open. Volvo doors will not lock if a door is open. P2 will lock after the door is closed. P3 and later will need to have the doors closed and then the lock button pressed again (I dislike this a lot)
Old Jul 22, 2022 | 08:57 AM
, saying that the driver door is not closed ,
There are microswitches in the inner door latch assembly that are supposed to close when the door latch is closed - could be a problem with one of those. The solution is a new inner door latch assembly - unless you have broken wiring - that would commonly be where the wires bend at the driver door hinge area.
mowntnbkr
Aug 26, 2011 08:12 PM
FRicart
Mar 18, 2011 04:28 PM
woodkayakr
Jul 9, 2009 12:37 PM
cm123
May 5, 2009 10:23 PM
jglass
Dec 7, 2008 10:56 AM
