Door Locks and Handels
Old Mar 17, 2011 | 11:05 AM
FRicart's Avatar
Default Door Locks and Handels
hi, need some help on a 850. front doors only work from the outter handels, and rears wont unlock thus cant open them at all.... ideas or suggestions would be greatly app. thanks
Old Mar 17, 2011 | 11:06 AM
boxpin's Avatar
Are the Child locks enabled?
Old Mar 17, 2011 | 11:43 AM
Will they unlock with the remote?
Old Mar 18, 2011 | 10:57 AM
FRicart's Avatar
Default Door Locks
Originally Posted by boxpin
are the child locks enabled?
no there in enabled..thanks
Old Mar 18, 2011 | 10:59 AM
FRicart's Avatar
Default Door locks
Originally Posted by rspi
will they unlock with the remote?
the remote unlocks the front doors only....i can see the locks seem to want to pop up but don't
Old Mar 18, 2011 | 11:35 AM
MattyXXL's Avatar
This may seem like a really stupid question but if you pull up the **** will they lift up?
Old Mar 18, 2011 | 02:33 PM
FRicart's Avatar
no a very good question... tried but they seem to be stuck in the locked position
Old Mar 18, 2011 | 04:28 PM
MattyXXL's Avatar
Do the windows roll down?
The reason I ask is does it sound like there is anything scraping when it goes down?
Id pull the door panel off and make sure everything is connected and nothing is jammed like a notorious window guide.
If you lift out the rear seat bottom You should be able to get the door panels off.
Id defiantly check the actuators... it could be your culprit.
im scanning some parts diagrams for you ill post a link in a couple mins
Code:
 http://www.mediafire.com/?dv7sjepm0sfik7c
rcvolvo
Jun 3, 2012 02:25 PM
mauriciogalvao
Feb 17, 2009 06:26 PM
fv70tech
Sep 17, 2008 05:26 PM
sid08
Jan 14, 2008 09:56 AM
ulandt
Dec 21, 2005 02:15 PM
