Need help with codes after trans change
Old Nov 15, 2012 | 04:58 PM
Deke MacPherson's Avatar
Default Need help with codes after trans change
I just had the transmission changed after the 99 v70xc AWD went south. I replaced it with a 98 FWD which according to everything i read is the same Trans. Also had the axle replaced. The car runs fine,shifts great but now the Check engine is on and shows the following codes.
P1618 fault in the lead between AW5052 and the MOTROME 4.3
P717----- turbine/input shaft speed sensor circuit no signal
I can't get it inspected with the engine light on.
ANY help with this or suggestions would be greatly appreciated.
Thanks,
Deke MacPherson
Old Nov 29, 2012 | 10:39 PM
Rdhcincy's Avatar
I would remove the CE lamp from the instrument panel and put back after inspection.
nortons
Feb 22, 2015 11:14 PM
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
