rear differential leak
Old Oct 21, 2015 | 10:46 PM
skee b's Avatar
Default rear differential leak
Good evening all.
I have a '00vr with about 164k miles. I recently noticed a couple of spots on garage floor at the rear of my vehicle. I put my car on a lift to find rear differential wet. Currently im running fwd as i have a failed prop shaft. Any procedures on how to reseal rear diff.?
Thank you.
Old Oct 22, 2015 | 08:56 PM
is it leaking from the drive shaft seal? I've had weepy seals on an old Audi and just pulled off the Axle (or prop shaft), pulled out the old seal and pressed in the new one. Just check to see if a special tool is required to set the seal to a specific depth or if it goes flush to the housing.
Ocicat
1998-2000 model year V70
Jun 9, 2013 04:09 AM
S60R-driver
Jan 27, 2010 08:22 PM
Beemer2002
Jan 24, 2010 01:43 PM
V70Pinner
Apr 17, 2009 03:04 PM
dads 740 turbo
Nov 13, 2008 12:14 AM
