Trans
Old Dec 16, 2015 | 05:49 PM
humncummins's Avatar
Default Trans
2000 v70xc car wont move in reverse fluid has been changed it started shortly after changing it. Is the trans no good.
Old Dec 16, 2015 | 05:59 PM
start by pulling OBD-II codes. You may see some errors pointing to solenoids. Its conceivable the valve body could be gummed up. If not then you can look into the shift position sensors or cabling. Also check the fluid level... (following the published procedure)
Old Dec 21, 2015 | 12:48 PM
bmdubya1198's Avatar
Do your reverse lights work? This may have to do with your PNP switch. It is one of the most common sources of transmission issues in the 850 and 70 series.
Also read the OBD2 codes. That could point you directly to the problem.
Old Dec 21, 2015 | 08:31 PM
pkrface's Avatar
What kind of fluid did you use?
Old Jan 25, 2016 | 04:51 PM
No codes at all reverse lights work when I put it in reverse you can feel it go in. It moves a little then stops all forward gears work good fluid is good.
nortons
Feb 22, 2015 11:14 PM
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
