ECU not signaling the relay for the SAS air pump.
Old Jan 11, 2022 | 01:00 PM
mswann60's Avatar
Default ECU not signaling the relay for the SAS air pump.
Hi, newbie here.
I have been restoring my 1998 V70XC for a bit, and am having a problem with the pump not coming on. No CEL or codes from the ODB.
New pump
Relay is good.
Power circuit wiring to the pump is good.
12 volt at terminal 86 when Ignition is turned on.
No ECU grounding signal at terminal 85 on cold start.
Vacuum to the air control valve on cold start. That pneumatic circuit is working OK.
Does anyone have any words of wisdom or a wiring diagram for that relay between the ECU and the relay terminal 85?
Thanks in advance for any help.
Old Jan 13, 2022 | 11:17 PM
mswann60's Avatar
OK, a buddy of mine with an All Par account let me know that the SAS relay signal wire is blue/pink, and it goes to B38 on the ECU. I'll check it out this weekend.
mswann60
1998-2000 model year V70
Jan 11, 2022 12:20 PM
duanny
May 17, 2018 03:41 AM
burroughmm
Aug 16, 2016 06:03 AM
tdrendel
Jun 14, 2013 12:06 PM
Shartzy4
Sep 26, 2012 10:28 AM
