aw50-55 Solenoid help.
Old Apr 18, 2015 | 12:17 PM
CrusherCurtis's Avatar
Default aw50-55 Solenoid help.
Anyone with any good links to DIY or Write ups on Solenoid removal. Can't find any Any good tips besides lowering the subframe? Probably going to tackle this tomorrow. Doesn't look to bad, it looks like its right in front. Will I need to support the engine when lowering the sub frame?
Old May 29, 2015 | 06:52 PM
benpf's Avatar
Default Valve Body Solenoids replacement
Have you already done the job? I just did the valve body 3 linear solenoid replacement on my car ('01 V70 XC).
A great reference is from the VolvoXC forum here: http://www.volvoxc.com/0/resources/h...ment-Notes.pdf
(assuming that you haven't already done it).
I didn't have to drain the radiator fluid, but I did flush (2 quarts at a time) all the transmission fluid until it came out bright red. Make sure you get new o-rings for the radiator and transmission cooling lines, especially the one on the transmission side of the lower cooling hose.
Good luck - let us know how it turned out.
VolPat
Feb 1, 2015 07:36 PM
Barcellos
Engine & Internal
Jan 27, 2014 08:11 PM
danthevolvoman
Sep 29, 2009 06:55 PM
wheelsup
Jan 10, 2009 06:52 AM
