B4204T 6DCT Simple Missfire?? (warmed up only)
Old Dec 11, 2021 | 03:05 AM
Kody Tht's Avatar
Unhappy B4204T 6DCT Simple Missfire?? (warmed up only)
Hello everyone. Please comment on my strange symptoms of my Volvo.
This is 2012 V70 T5 2.0 B4204T 6DCT 110k miles.
The problem seems to be that the engine has misfired at irregular timings since it warmed up.
[Symptoms]
・ The engine is warm. About after running 10km (or 15 minutes).
・ Load on the engine. Step on the uphill or accelerator.
・ Vibration as if stepping on a narrow seam on the road. Misfire. The rotation goes up and down about 200 rpm.
【Current status】
・ There are no error codes and messages.
・ No symptoms appear in the morning or when the engine is cold.
・ No symptoms appear even if I stop and rev.
・ No symptom appears when the accelerator pedal is kept constant.
・ There are 2 sets of 4 plugs, 4 IG coils, and 2 sets of MAF sensors, so I tried to replace them.
・ The DCT is replaced with a new one.
【Predict】
・ Plug leak (I tried 4 NGK and 4 Ford, but the root seems a little brown)
・ High-pressure fuel pump (Failure product arrives and is replaced)
・ Injector clogging
Which one do you think? Have you ever seen such a symptom?
thank you for reading. Nice to meet you.
Old Jul 16, 2023 | 01:22 AM
Kody Tht's Avatar
It was the transmission oil. sparse or dirty.
When I changed the DCT oil and oil filter, things got better.
I am the cause of everything.
I didn't know that a misfire error would appear if there was a problem with the transmission oil. Lack of knowledge.
I'm writing this here in hopes that it will help someone find a solution. Thank you.
Old Jul 16, 2023 | 03:14 AM
V70_man's Avatar
Have you checked the ignition coils?
Sure, usually they give the error code but not always.
auidiveight
Jan 21, 2020 01:02 PM
good1662
Feb 11, 2018 10:00 PM
inckka
Aug 14, 2017 08:47 AM
Pinnie
1998-2000 model year V70
Jul 5, 2013 08:14 AM
Turkey_Sandwich
Jan 28, 2012 10:27 AM
