Help!, Heavy engine vibrate with posible misses.
Old Aug 14, 2017 | 08:47 AM
inckka's Avatar
Default Help!, Heavy engine vibrate with posible misses.
99 Volvo S40 MK1
I recently noticed on low RPM when I paddle for gas, the engine was kind of missing a little bit. Couple of days back problem got worst and I heard engine kept knocking and it sounded bit strange (like a truck engine)
- There's no warning lights on dashboard. Scanned the ECU for error codes, But found 0. If its misfire, computer should notice that right?
- Is this bad fuel problem?
- Checked the plug and coil connection area, there was an old oil spill there which happened long time a go (like a year ago), still got some moisture. I assume if it shorts the circuit, a misfire should appear and 'Check Engine Light' should come ON right?
Any suggestions are really appreciated to troubleshoot this issue.
noruckus
Mar 2, 2015 10:31 PM
greg 850T
Jul 12, 2011 07:56 AM
BorninBflo
Jun 30, 2008 10:58 AM
roundoldman
Jun 9, 2008 05:22 AM
pconfar
Dec 10, 2007 06:11 AM
