Brake Lights
Old Mar 8, 2014 | 10:24 AM
CHILAND's Avatar
Default Brake Lights
I have a problem with the brake lights on my 2002 V70 Basic not working.
I checked fuses, OK. Check bulbs also OK, then check for voltage at the bulb socket and there was none. Found a bulletin to replace the brake light single relay with two upgraded relays to solve this problem which I purchased from Volvo and installed. Still no brake lights. Thought I should add also checked for ground. Any other suggestions would be greatly appreciated, I am at wits end. Thanks in advance.
Old Mar 9, 2014 | 04:40 AM
stop_at_willoughby's Avatar
Is it on both sides or just one side? Also are all the other lights in that cluster of bulbs working?
Old Mar 9, 2014 | 09:15 AM
CHILAND's Avatar
Both sides are out plus the rear fog light. The rest of the lights are working. Like I said I replaced the relay with two upgrade relays in the REM. I also found a post with instructions on testing the shunt in the REM which I did and it was good.
Old Mar 9, 2014 | 07:11 PM
CHILAND's Avatar
Boy did I really miss the obvious. Some way, a senior moment, I missed checking the 7.5 fuse in the REM. After reading a great description along with a wiring diagram. I decided to check again and the 7.5 fuse was missing. I was just testing all the fuses in the REM and did not catch that it was not there.
aznyaz
Jan 9, 2015 02:38 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
Scott V
Jul 21, 2013 02:28 PM
Mellott
Jun 13, 2011 11:41 PM
chrystald423
Mar 27, 2010 08:05 AM
