evap code on '01 xc70
Old Jul 15, 2015 | 01:23 PM
drenman's Avatar
Default evap code on '01 xc70
So I just bought and '01 V70XC and the check engine light came on in the first 100 miles after I put the plates on. The local autoparts store gave me a code listing all the possible reasons for the evap system not working, I did the first and cheapest thing and swapped out some cheap plastic gas cap for the one that didn't look at all right, or OEM. The autozone one was still plastic, but better, maybe I should get at OEM from the stealership or FCP/IPD?
tank, vacuum lines, etc. also came up... It's good on emissions so I'm just doing my part to help global warming for now, but I'd like to get rid of that code. I drove it another 170 miles with the new cap, which should have cleared that code in about the first 50...
Any ideas before I start chasing down parts? The filler neck seems to have SOME play in it, and I know that the trans was changed out before I bought it.
THanks...
Old Jul 15, 2015 | 02:14 PM
ES6T's Avatar
What's the code?
Old Jul 15, 2015 | 06:11 PM
drenman's Avatar
So keep in mind it's an autozone computer not a Volvo dealer one, and it says...
P0455
EVAP large leak detected
Explanation
The ECM has detected a large leak in the EVAP system during a system monitor test
Probable Cause
1. Defective, loose, or missing fuel cap
2. Evap canister broke, hose cracked or not connected
3. Purge or vent solenoid defective
4. Vacuum leak at engine
I did replace the fuel cap, but it was a cheap $10.00 plastic one, of note my older '94 940 had the same problem with the cap during emissions testing, replaced it and it fixed it.
I'm wondering if I just need to get a better quality cap, or if the code isn't clearing, or...my problem is more than just a gas cap?
Old Jul 15, 2015 | 06:25 PM
ES6T's Avatar
Best bet is to have the system smoke checked. Or have the codes read with a dealer scanner. Could be the leak detection pump. Could also need an ECM update. Volvo has free diagnosis.
Old Jul 17, 2015 | 01:19 PM
drenman's Avatar
Solid Brother! Thanks, will do.
(I love this car, I swore I'd never buy a non RWD redblock, but....if this is wrong, I don't want to be right!)
Old Jul 19, 2015 | 01:20 PM
drenman's Avatar
So I took it to the dealer, they wanted $116.00 just to plug in their computer and dx. it. That's why they call it a stealership.
So, on I go... maybe a smaller Volvo specialist can help, mom and pop place or Euro/Swede specialist repair shop.
Old Jul 19, 2015 | 09:01 PM
ES6T's Avatar
Ask them why they don't participate in this:
Volvo Advantage Complimentary Services | Volvo Cars
All dealers are supposed to as far as I know. Contact Volvo Customer Care if they don't.
Old Jul 20, 2015 | 05:37 PM
drenman's Avatar
I will, thank you.
Also.... I'm pretty sure the brake booster is going...either that or someone installed an aftermarket air compressor right next to my brake pedal...
Not cool... I'll be having words with the lot who sold me this car.
Old Jul 20, 2015 | 05:55 PM
drenman's Avatar
Actually, considering the codes that came up, could these be related? I mean, I wouldn't think that the EVAP code would be related to a brake booster leak, and that's GOT to be the hissing noise by the pedal, I haven't looked yet but I'm sure it's the bellows, I've looked into the causes, google is my friend here, but I'm wondering outloud if the cheapy diagnostic computer maybe is reading this wrong, sounds like I need a Volvo dealer to check this out, or take it back to the lot I bought it at and tell them to fix this thing pronto.
Still, I did buy it as is and I want to head off any possible repairs I might be stuck with if they give me a hard time.
I've seen RTV sealer fixes for $5.00 vs. replacing the booster at $700.00
Old Jul 20, 2015 | 08:08 PM
ES6T's Avatar
A booster won't set an evap code. I don't know if I'd trust an RTV fix. Never tried it though... We have to replace the booster to cover our asses.
skatermattc2
Jan 10, 2020 10:01 PM
jblough99
Oct 13, 2010 07:53 AM
Byroni616
Apr 14, 2008 08:10 PM
jmd
Mar 28, 2008 10:51 AM
nbac3k
Nov 20, 2007 06:46 PM
