handbrake adjustment
Old Jan 19, 2015 | 01:31 PM
joeevans's Avatar
Default handbrake adjustment
Hi, My handbrake appears to be very high and has little to no hold when stationary. What is the best way to adjust the cable/shoes? There are adjusters near the shoes and another on the handbrake casing I believe. Do I need to loosen the handbrake adjuster before tightening the adjusters near the shoes then tighten the handbrake adjuster. Any help would be appreciated??
Old Jan 19, 2015 | 01:51 PM
ES6T's Avatar
The only adjustment is at the lever.
Old Jan 19, 2015 | 04:06 PM
joeevans's Avatar
Ok so the lever is the only adjustment. So failing this could I need new shoes?? If so, would I need to loosen off the lever adjuster before changing them then tighten after fitted? Thanks
Old Jan 19, 2015 | 04:33 PM
ES6T's Avatar
You'd have to inspect the shoes, but it's possible. They come apart all the time. You would need to loosen the adjustment to remove the rotors.
Old Jan 20, 2015 | 09:00 AM
joeevans's Avatar
I have inspected the handbrake cable adjuster the adjustment is relatively high so on that basis, I assume that the shoes may need changing prior to inspection. Could this be correct?
Old Jan 20, 2015 | 10:42 AM
ES6T's Avatar
That would be the most likely situation.
Old Jan 21, 2015 | 10:10 AM
joeevans's Avatar
Ok I will inspect the shoes prior to purchase. Thanks for your help!
Old Jan 22, 2015 | 07:19 PM
shoeboxOH's Avatar
I did not lessen the tension on the handbrake prior to removing rear rotors & the parking brake pads delaminated. Future note: do not do this.
Old Jan 22, 2015 | 07:22 PM
ES6T's Avatar
If it makes you feel better, they do it all the time. I doubt it was your fault. It may have been the straw that broke the camel's back, but they would have come apart anyway- possibly while driving- which causes all sorts of damage. So you were better off.
Old Jan 22, 2015 | 07:36 PM
shoeboxOH's Avatar
I bought a kit from fcp but I just haven't gotten around to installing them. I'm hoping it's an easy job.
Old Jan 23, 2015 | 12:57 PM
shoeboxOH's Avatar
Is there a video or quick tutorial on how to access the adjustment.on the lever? I really don't want to rip the fabric to access it.
Old Jan 23, 2015 | 02:11 PM
ES6T's Avatar
The trim just pulls straight up.
Old Jan 24, 2015 | 03:48 AM
joeevans's Avatar
There is a video on YouTube. Has said above the trim just pulls up there maybe a plastic cover over the adjuster nut however these seem very flimsy
Old Apr 13, 2015 | 09:57 PM
shoeboxOH's Avatar
I just installed new pads & springs this weekend. Not a bad job at all. I started with small glad head screwdriver at the rear of brake handle. It basically has a few clips on the inside (toward passenger seat) & three tabs on driver side. Pops right up. 10mm deep socket (least on mine) to adjust cable tension. Clockwise loosens tension. Counter tightens. Dialed mine in to 4-5 clicks & car stops on a dime. Few youtube videos on how to take out fixing springs helps as they are a bit of a challenge. No special tool needed, just long nose needle nose.
rolling2
Jan 18, 2013 12:55 AM
nextproject
Nov 16, 2009 07:04 PM
Mass850
Oct 8, 2005 04:54 PM
olaf849
Jul 1, 2005 06:46 PM
asfd
Feb 14, 2005 12:00 AM
