Intermittent cyl 1 injector issue
Old Jan 9, 2021 | 12:03 PM
dobrosailor's Avatar
Default Intermittent cyl 1 injector issue
I have a 2002 Hi Pressure Turbo motor. THe car runs fine for 90% of the time but at idle it gets an intermittent misfire. When it idles good, its smooth as can be, when it misses its only one cylinders worth of miss. I have done the following:
New VOlvo Plugs
New Bosch Ignition Coils
Swapped around Injectors
Cleaned throttle body
When I had the motor out, I cleaned the PVC system, pulled the pan and cleaned it out and the PVC passages. New belt etc. All new motor mounts...
I have isolated it to the number 1 injector. If it is missing and I Pull the #1 injector plug when it is misfiring, the misfire doesn't change, all the others do change. I have swapped around injectors till I was blue in the face as they say, I have an entire second motor's worth of injectors, made sure they were the same s/n as the ones on the installed motor, I am convinced it is not an injector plus I cleaned them with my home made cleaner.
Background, I pulled the motor out of a T5 when my old one overheated and roached. the car has 165k, the motor 110 k. I replaced the vacuum hoses and have retraced them a thousand times making sure the one-way valves were oriented correctly. Couple of I believe non-related issues:
Twice in the last month I started the car and got a ECT light and the throttle did not work. I restarted a couple of times and it has been fine each time. Eventually the light goes away.
If I floor it, the car takes off like a scalded rabbit, if I give it 1/2 or to 3/4 throttle it missfires, not just one cylinder it really misfires till I floor it. First half of the throttle works fine.
I think both these problems are likely related to the ECT needing an update to magnetic but not sure.
I love this car its actually a 1gen C70 but I post here due to the sheer volume of viewers and its specific to this era car which has its own idiosyncrasies e.g. ETC. I have wrestled with these problems for 2 years and have posted before likely. It is my daily driver and runs great, I invested in it to keep it for 10 years e.g. all new motor mounts etc. Would love to solve this idle issue...
Best regards, Mark
Old Jan 9, 2021 | 02:41 PM
Originally Posted by dobrosailor
I have a 2002 Hi Pressure Turbo motor. car runs fine for 90% of the time but at idle it gets an intermittent misfire.
I have isolated it to the number 1 injector. .
ECT light and the throttle did not work. If I floor it, the car takes off like a scalded rabbit, if I give it 1/2 or to 3/4 throttle it missfires, not just one cylinder it really misfires till I floor it. First half of the throttle works fine.
I'd look at (replace) the throttle - Your c70 has the Magnetti mareilli (sp) throttle module - has it be replaced? I'm guessing that's related to your "ECT update to magnetic" comment.
If you have VIDA or a compatible scan tool you can test/monitor the throttle module operation.
Old Jan 10, 2021 | 07:40 AM
It has the white label ECT and it has not been replaced. I am living in a motorhome while I purchase a new home. As soon as I have a garage, I will convert the ECT. I will run the car by the local volvo whisperer and have him vida the system - good idea...
dobrosailor
2001-2013 model year V70
Feb 21, 2021 11:10 AM
SwedishFury
Sep 11, 2015 10:53 AM
Aredd95
Aug 20, 2015 11:08 AM
TN240Volvo
Dec 22, 2014 09:06 AM
simcorp7
Apr 23, 2009 07:05 PM
