Mirrors re-setting
Old Feb 28, 2012 | 03:48 PM
Scubademon's Avatar
Default Mirrors re-setting
Hi there.
I have saved my mirror and seat positioning on Pos. 1 of the automatic seats, however, when I switch the car off and back on, the passenger side mirror always resets to the most outward position possible. The driver side mirror remains in place. If I press the button next to the seat, the mirror returns to the stored position, so positioning obviously remains saved.
It is a bit of a pain to have to remember to manually set the mirrors every time you get back into the car, so does anybody have any ideas on how to fix this?
Cheers,
The Scubademon
Old Apr 24, 2012 | 11:14 AM
65mustang's Avatar
This may not be your exact problem but maybe something to try. The seat memory is also tied into the key fob. Try setting your seat to position 1 like normal. Get out and close the door. Lock it using the key fob. Unlock it using the key fob and it should be set. It has worked for me anyway. Good luck.
Old May 13, 2012 | 01:50 PM
Will Smith's Avatar
I have a similar issue, when I open the car with the fob and then go to open the door the driver side mirror goes upwards
Old May 16, 2012 | 12:47 AM
Will Smith's Avatar
Took the Car the the Main Dealer who had to reprogram the mirror. now work just fine!!
TexFinn
Sep 22, 2009 08:08 PM
micah360
May 28, 2008 04:14 PM
dukesdbomb
Feb 10, 2007 10:28 AM
tenpiloto
Nov 27, 2005 09:02 PM
oalsa
Nov 16, 2005 10:45 PM
