Interior fan works on low setting only, Brake Failure Urgent Service.
Old Nov 15, 2005 | 04:03 PM
oalsa's Avatar
Default Interior fan works on low setting only, Brake Failure Urgent Service.
My AC works fine. I can hear the compressor kicking in, but the fan controller inside the car works on the low setting only. My other problem is the Brake failure message. The brakes are fine, but when I hit on the breaks I can hear an air leak sound. The message comes on when I drive locally and disappears on the Hwy, probably because I hit less on the breaks on the Hwy. I also have this funny message....Bulb failure postion required!!! Any input on these messages? Thanks.
Old Nov 15, 2005 | 08:56 PM
Default RE: Interior fan works on low setting only, Brake Failure Urgent Service.
The first problem is most likely a bad blower motor resistor.
The second problem sounds like a bad brake booster.
Old Nov 15, 2005 | 10:01 PM
oalsa's Avatar
ORIGINAL: tech
Thanks Tech. Are these expensive to fix, and is it something that a local mechanic shop can do? I mean are there any software upgrades or downloads involved? Thanks again.
Old Nov 15, 2005 | 10:10 PM
oalsa's Avatar
Can this be the ABS module?
Old Nov 15, 2005 | 10:22 PM
VolvoTechCMC's Avatar
negative, if you hear a constant hiss than the brake booster is leaking. be prepared to pay for it tho. Booster is pretty expensive. the bulb failure is exactly wats its saying, Walk around the car and ill guarntee you, you have a bulb blown........
Old Nov 16, 2005 | 08:31 PM
Yes it is pretty expensive but no software required.
Old Nov 16, 2005 | 09:24 PM
oalsa's Avatar
Hi again. My mechanic is telling me that the resistor for the blower motor controls the low speeds, and since I have the blower working in low speed only, then, he thinks, that it might be the control switch board and is advising to change the whole control switch board from a junk yard. What do you advise, do the resistor or the switch board......or both? Thanks for all your help.
Old Nov 16, 2005 | 09:34 PM
Did he check the wiring and make sure the resistor isn't bad?
The newer cars are a little different. The resistor is mounted in by the blower motor.
The control panel won't just plug and play. It will need a download if it can even be reloaded.
Old Nov 16, 2005 | 09:42 PM
oalsa's Avatar
No he did not do any wiring tests. He is a know it all kind of guy. I will tell him what you just told me. Can you possibly tell me where exactly the resistor is located. Is this is something I can do at home? If so, do you have the steps for doing it? Thank you so much.
Old Nov 16, 2005 | 09:55 PM
It has been a little while since I had one apart but it is under the dash on the passenger side. If you remove the motor from the box it comes out in a case like thing. The resistor is mounted under the motor.You will have to slide the motor out of the housing to get to the resistor. To remove the motor out of the housing you will have to remove 2 screws.
I wisj I had more info for you but like I said it has been a while.
Old Nov 16, 2005 | 10:01 PM
oalsa's Avatar
Thank you. I will give it a shot and update you on it. I also found a brake booster for $50. A used one. Thanks again.
Old Nov 16, 2005 | 10:07 PM
Are you going to install the booster?
That is cheap good luck!!
Old Nov 16, 2005 | 10:31 PM
Yeah, if you do decide to replace the Climate control module, it will have to be downloaded. Tell ur mechanic to add that to his know it all capabilities!~
Old Nov 16, 2005 | 10:37 PM
oalsa's Avatar
If you think it is OK to do then I will try. Otherwise I will leave it to my mechanic. He's charging me $150 to do it. This is reasonable, I think. My wife is driving a 1999 s80T6. The computer gave signals of ABS and STC service and the instrument cluster quit working. She parked her car and restarted and all went back to normal. I sent the ABS module to the rebuild shop in FL for $75 as you probably know. We installed it last week. No problems until today when the same problems re-occured. She just told me and I am so frustrated. I do not know whose at fault. Is it the rebuilder or was it another problem from the start?
Old Nov 16, 2005 | 10:45 PM
oalsa's Avatar
I will list my S80 concerns in the S80 forum. Thank you all.
robingichuhi
Feb 22, 2017 04:34 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
mnvolvo
Mar 1, 2012 11:16 AM
dukesdbomb
Feb 10, 2007 10:28 AM
Nemesis
Oct 14, 2004 11:55 PM
