No power locks, sunroof, or reading lamps. Help?
Old Jul 1, 2012 | 11:54 AM
volvo18123's Avatar
Default No power locks, sunroof, or reading lamps. Help?
I have checked all the fuses but everything appears to be fine.
Old Jul 1, 2012 | 01:41 PM
Try to jiggle the ignition key to see if that helps. Older Volvo's have problems with the ignition.
Old Jul 3, 2012 | 09:50 AM
hughrhodes's Avatar
same problem. No reading lights when I push the buttons BUT do come on when I open the doors. Sunroof stuck in up position as well.
Old Jul 20, 2012 | 09:02 PM
kenpack1's Avatar
Default Been there done that
The problem comes from either you replaced your power mirror recently or the alarm siren battery has failed. I had to replace the siren that is located under the front fender well of the passenger side. Wheel off and fender plastic wheel well off(drill rivets out) you will then see the alarm siren.
Also to test the mirror possibly being the cause i would suggest unplug the mirror and reconnect. The siren will sound for about 30sec and stop. the sunroof will work for a short time after (I give it 5 min), the reading lights will also work albeit temperary. Hope this helps you out.
meburt02
Jul 3, 2012 09:56 AM
MissMichele26
Sep 2, 2010 11:09 AM
benicetoyourvolvo
Jul 31, 2010 04:18 PM
volvofamily
Sep 15, 2007 07:32 AM
vinnievolvo
Apr 6, 2005 12:50 PM
