Our headlight squirters
Old May 10, 2019 | 09:39 AM
Georgeandkira's Avatar
Default Our headlight squirters
I have a 2007 V70 base.
Can the headlight squirters be disabled?
For my situation they are not at all needed. The spray flies onto the hood and windshield at speed.
Thanks G&K
Old May 10, 2019 | 10:43 AM
did you try disconnecting the headlight wiper motor or do you want to retain that function? Not sure if that will stop the water flow but I think there is a T connector over on the passenger side inner fender to send fluid from the pump to the headlights and up to the hood. You may be able to replace that with a straight tube to shunt the water feed to the lamps.
Old May 10, 2019 | 04:38 PM
There's no wiper. It's just a jet of fluid.
I wanted to gather as much intel as I could before going in and disconnecting things.
For example: Are the squirt jets 100% fluid pressure powered or do they raise electrically?
Is there more than one washer fluid pump or is there a super strong booster pump in the bumper near the squirter?
Old May 10, 2019 | 07:16 PM
ES6T's Avatar
Remove the fuse for the headlight washer pump. Check your owner's manual for the location.
Brookecollier23
Mar 23, 2011 09:17 PM
rtm
Jul 15, 2009 01:03 PM
twowheelin
Mar 18, 2008 11:10 PM
Genna
Feb 15, 2007 03:33 PM
97volvo850
Aug 27, 2006 12:11 PM
