Hi,
My V70 cranks but don't start. I don't get any error codes but when connecting an obd scanner it shows a slow build up of the high fuel pressure, it takes 5 seconds to reach 360 bar (5200 psi). (Assume it should go much faster)
Some background info, I took of the dpf, cleaned it and set it back. Engine started directly but after a few minutes the engine was getting slower and after a few more minutes I stopped and it was not possible to start again. So removed the dpf again and tried started without it (to exclude dpf as the source of problem)- but without success.
How is the low side fuel pressure?
Filter filter is newer than older?
No kinked fuel supply hoses?
Nothing electrical damaged during the DPF removal/install? All connectors plugged back in if removed?
