Stuck doors, problems with REM volvo v70 2001
Old Oct 28, 2019 | 01:22 PM
Robbie147's Avatar
Default Stuck doors, problems with REM volvo v70 2001
Hello everyone, i am experiencing serious issues with my car, my reverse lights wont work, gas gauge shows nothing, my rear passenger doors are stuck at the point that you can't even open them from inside and central locking opens only drivers and front passengers doors, can't fill fuel, because the small door for the fuel cap is also locked, rear hatch is locked as well, rear wipers wont work, rear washer also not working, and rear windows heater also not working for me.
Before this i experienced that rear fog lights are not working, they are still not working, but it wasn't that big of a deal.
I tried REM reset, once it worked few weeks ago, now there is no sign of life at all, tried resetting REM, battery - nothing.
I was driving, everything was okay, gas gauge was working , i turn off the car, lock the doors, few hours later, opening my doors, only front doors opens and you already know what happens.
Volvo v70 2001 2.5 tdi manual.
Old Oct 28, 2019 | 01:53 PM
you check all fuses and relays yet? You may also need to look at a wiring diagram to see where there are common connections - ie relay, CEM, fuse, ground points that service the noted circuits.
Old Oct 29, 2019 | 09:16 AM
Robbie147's Avatar
This time everything again works after doing REM reset without central locking fuse, but after the rem reset i inserted the central door locking fuse and it is still working, but this has happened multiple times and every single time it's different solution to fix it for a short while
Old Nov 11, 2019 | 02:09 PM
Robbie147's Avatar
Happened again, before this happens i hear clicking sounds at the rear, sometimes i can't turn on the car because battery is dead, but its quite new and still has a warranty... went for inspection at two places, they couldn't solve the issue, took money for inspection to find nothing...
kensager
Mar 27, 2023 02:40 PM
jaddley
Apr 1, 2012 04:25 AM
my volvo
Oct 31, 2011 09:13 PM
mfroese
Nov 18, 2010 11:34 AM
n3cr0
Jun 8, 2010 07:05 AM
