V70 2002 - Windscreen Washer
Old Aug 7, 2018 | 04:24 AM
southwesty's Avatar
Default V70 2002 - Windscreen Washer
Hi,
My front windscreen washer isn't working, however the back one is. The pump does not make any noise when i activate the washer. Do the front and back washers work off separate pumps, and is this most likely a case of the front pump needing replacing?
Thanks .
Old Aug 7, 2018 | 01:45 PM
tony1963's Avatar
Yes, to my knowledge, most had a two pump system. I've only ever replaced a few of these and the ones that I worked on had two pumps fitted.
To change the washer pump, remove the front bumper cover. That's the easiest way to access the components. Removing the front bumper cover isn't hard at all.
Old Aug 8, 2018 | 03:40 AM
southwesty's Avatar
Thanks! Great help
BackCountry
May 9, 2021 06:02 AM
twn22
Volvo C30
Jan 15, 2016 04:33 PM
johnpostill
Feb 18, 2015 01:32 PM
Rosew6211
Nov 23, 2010 11:05 AM
blahop
Dec 5, 2005 08:59 PM
