Can I check hoses at bottom of washer tank without removing bumper?
Old Feb 1, 2015 | 11:46 AM
lropeik's Avatar
Default Can I check hoses at bottom of washer tank without removing bumper?
2009 XC70 T6
I've got a leak right below the washer fluid reservoir--a steady drip that empties it completely. When it does have fluid, all five sprayers work fine. I suspect a loose or cracked hose/connector.
Is there any way I can get a look at the connections, all of which are near bottom of the reservoir, without completely taking apart the front of the car?
Thanks
Old Feb 1, 2015 | 04:25 PM
ES6T's Avatar
It's usually the headlight washer hose, which can be seen by removing the fender liner. However, to replace the hose, the bumper is removed. Or you can try to patch it I suppose.
97black850
May 27, 2021 09:49 AM
wallst32
Aug 29, 2011 07:30 PM
GoldS701999
Jul 18, 2011 01:00 PM
apriliaguy
Oct 30, 2008 08:23 PM
