No Drive When Very Cold
Old Dec 9, 2020 | 01:39 PM
RJSV70's Avatar
Default No Drive When Very Cold
Hi
Mine is a 2006 XC70 with 178K miles. I have owned since 145K and performed an ATF fluid drain/replace myself at 150K with the proper spec ATF (Mobil JWS 3309). All is good - transmission performs flawlessly. But, have noticed only when the car is parked outside all night in temps below 25*F (like last night here in CT) the car has no forward drive. For the first 1/2 miles the engine will run at 2000 RPM while the car creeps along our street at 5mph. After that, all is fine. BTW, reverse works fine.
I am hoping this is no more than low ATF level - there's a reasonable chance I messed the level when I did the drain/replace. And, I understand ATF is very temp sensitive (i.e. it expands or contracts a lot with temp).
Anyone have experience with this or with low ATF levels? I'll try to check the level at the weekend
Bob
Namo
Feb 29, 2020 05:46 AM
tony1963
Aug 4, 2018 01:03 PM
mt6127
Nov 19, 2016 08:01 PM
dlundblad
Jun 19, 2015 07:59 PM
ecberr
Jan 5, 2010 10:49 PM
