Purge control valve
Old Apr 22, 2018 | 02:08 PM
john gill's Avatar
Default Purge control valve
I originally posted this question in the v70 forum but it occurs to me I actually have a 2002 V70XC AWD. (196K)
Anyway, I am attempting to locate the purge control valve and the vent control valve. Since my original post yesterday I have located the purge control valve under the intake manifold. It was a bit of a pain to get it out but it seems to be working properly and not the cause of the engine code and #5 fuse blowing.
Thanks again and sorry for the confusion.
THIS IS THE ORIGINAL POST I PUT IN THE V70 FORUM:
I have an 02 v70 with 196000, love this car!
Recently the check engine light came on, other than that there were no adverst symptoms. I had the codes checked and came up with the following:
PO245 WASTGATE SOLENIOD A LOW
PO445 PURGE CONTROL VALVE CIRCUIT SHORTED
PO448 VENT CONTROL SHORTED
P2401 LEAK DETECTION CIRCUIT LOW
P2090 CAMSHAFT POSITION CIRCUIT LOW
Sounds catastrophic at first glance but a search through this fourum sent me to the #5 fuse in the under hood fuse panel. This fuse powers all the systems above. Replaced the fuse and it blue right away.
OK showing two potentially shorted circuits I am going for the control and vent valves. I strongly suspect the vent valve due to a intermitent fuel smell that I have noted over the last couple of months. I did replace the fuel pump recently due to a leak and figured that was the cause of the smell, it helped but was not the whole story.
OK to my question asuming the vent valve is the culprit were is it ??
If the vent valve proves to be good then were is the purge valve ??
I found what I thought to be the purge valve under the hood attached to the side of the air filter box but it dose not look anything like the photo of the replacement ( to many hoses)
To tell you the truth I feel a bit dumb asking but I have looked and its hidden pretty good,
Thanks in advance
__________________
overgill
john gill
2001-2013 model year V70
Apr 21, 2018 01:23 PM
chachouu
Apr 8, 2010 03:51 PM
holobox
Sep 28, 2009 08:04 PM
drizzledazzle
Oct 9, 2007 06:31 AM
1996850turbo
Jul 31, 2007 08:44 PM
