Tarnsmission question
Old May 16, 2009 | 01:29 PM
Nick960's Avatar
Default Tarnsmission question
The check engine light came on on my 96 Volvo 960. It was followed by the W and E lights flashing near my shifter, and the arrow light (transmission) flashing on the dash. I stopped the car and fiddled with the shifter (moved it back and forth) and when I started it back up, no more flashing W, E or arrow lights until I got close to home, when the flashing lights started again. The error code reported is PO715 (speed sensor input error). Where is the speed sensor? Is it part of the PNP switch? I can;t find a part number.
Old May 17, 2009 | 09:55 PM
Brian Mc's Avatar
Try this- with car parked engine off go from park to low about 20 times like your sawing a log.
CLeans the contacts in the PNP switch
I had the same problem,symptoms and codes on mine this cured it.
Old May 19, 2009 | 08:51 AM
Nick960's Avatar
Default Still flashing
That makes the lights go out when I start it but within a few minutes the check engine light comes on again and if I start driving, all the flashing starts again before I hit the end of my street.
Old May 19, 2009 | 07:24 PM
You need to get the codes pulled.
Old May 20, 2009 | 08:03 AM
Nick960's Avatar
Default Po715
The code is PO715.
Old May 20, 2009 | 08:16 PM
That code is for the transmission speed sensor.
96850urbo
Jan 23, 2009 01:00 PM
Adrenalin540
Dec 31, 2008 10:19 AM
Aaronius
May 30, 2008 06:10 PM
pvolvoman
Oct 24, 2007 07:29 PM
mordezmoncou
Apr 9, 2007 05:22 AM
