S70 front speakers intermitent
Greetings,
I have a 98 S70 with stock stereo, AM/FM Cassette (no CD), and 6 speakers. For the last month the front door speakers have been intermitantly turning off. Sometimes both will turn off at the same time, sometimes only the drivers side, and sometimes only the passenger side. I think that sometimes the intermitent behaviour is caused by driving over bumps, but I might be imagining things. I took out the head and it looked like the wires were pretty well attached. I also took off the passenger side door panel to check the wires, and they seemed to be well attached, although i don't really know what I'm doing. The intermitent behaviour will often occur while the stereo is on and change every 5 minutes or so (i.e. front speakers on for 5 minutes, one speaker turns off for 5 minutes, etc). Rear speakers are fine, and dash speaker are fine.
Any ideas?
Thanks!
Any ideas?
Thanks!
ORIGINAL: cbevis
Stock decks wear out and the speakers are usually the first thing to go. Sounds like you need a Head Unit.
Would a new Volvo, or aftermarket head unit be better?
Should the speakers last for a while, or should I think about replacing them too?
Thanks!
I wouldn't go the route of a used unit unless you have the opportunity to install it in the car and test it out first. Not only do the speaker channels go out the power/volume **** goes bad as well and makes an irritateing scratching noise whenever you touch it. Also, sometimes when the speaker channels are going bad the problem won't manifest itself till the stereo has been on for a while so a quick plug and sample of the head unit may not expose the problem.
You could always go to best buy or somewhere and pic up a deck and install kit that will sound just as good for a couple hundred dolllars and not have to worry about these problems.
