Intermitent Speedometer
Old Jul 4, 2008 | 08:11 AM
lister99's Avatar
Default Intermitent Speedometer
My 96 850 turbo speedo has stoppedworking intermitently while driving. Sometimes when the car is shut off it will work again. Any ideas on what I need to replace to correct this. Thanks in advance for the help.
Old Jul 4, 2008 | 08:37 AM
Default RE: Intermitent Speedometer
Any Check Engine or ABS codes?
Old Jul 4, 2008 | 08:45 AM
lister99's Avatar
No, check engine light is not on, so I assume that there are no codes. It would come if there where would it not?
Old Jul 4, 2008 | 08:55 AM
Sometimes there might be codes and no lights.
Old Jul 4, 2008 | 09:09 AM
lister99's Avatar
Guees I need to buy a code reader, JPN recommended an Acutron I believe. You have a favorite?
Old Jul 4, 2008 | 09:16 AM
Sorry but I don't.
At work we have a Volvo based one. That is my favorite but it would set someone back about 3K.
The Actron work pretty good.
There could be codes in the ECM,ABS,TCM that could cause the speedo to stop intermitently
Old Jul 4, 2008 | 09:19 AM
https://volvoforums.com/m_75823/tm.htm
Also read through this post and see if it helps.
Old Jul 4, 2008 | 11:09 AM
autoxray's Avatar
Tech orJPN,
Regarding the Actron scanner, I notice there are several different models. Any suggestion which model is good for reading and clearing codes? Also, how do they compare to the one IPD sells?
Old Jul 4, 2008 | 07:45 PM
lister99's Avatar
Both the speedo and the odo don't work at the same time, should I assume that it's that little $25 gear that needs to be replaced ?
Old Jul 5, 2008 | 01:35 AM
Psaboic's Avatar
No, I think that would tend to point toward broken wiring going to the speedo unit. When (not if) the gear breaks it takes out the odometer, but the speedo will still work.
Old Jul 5, 2008 | 05:21 PM
lister99's Avatar
That was along the lines was thinking (towards the sending unit or the gauge itself) after looking at the pictures for repairing the gear it is inside the odometer unit only. Thank you
Old Jul 6, 2008 | 04:59 AM
mygreat850turbo's Avatar
Is your ABS/track warning lights on?
If so, you have a defective ABS module.
That was what I did to fix my speedometer problem.
Let me know if I can assist you any further.
John
1996 Volvo 850 Turbo
iamcanadian
Jun 22, 2008 08:44 AM
magak2572
Apr 27, 2008 09:34 AM
scotty
Feb 7, 2008 12:07 PM
festivus
Feb 19, 2007 08:03 PM
ttron
Nov 8, 2005 01:14 AM
