Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
stock radio trouble
Old Sep 9, 2009 | 12:54 AM
boldtu's Avatar
Default stock radio trouble
I recently bought a 1997 850 R Wagon. The stereo is only generating sound out of the two dash speakers and the passenger door speaker. There is a very small amount coming out of the rear door speakers (at full volume) and none out the rear D pillar speakers. It sounds like a head unit issue to me but I wanted to ask you guys what you thought before I went out and made some attempt at fixing it. Also is it possible to run an ipod through the CD changer connection in the back of the head unit? Very happy with my new car otherwise.
P.S. If I do need to change out the head unit and probably speakers what would you recommend for a reasonably priced stereo.
Thanks,
Chet
Old Sep 9, 2009 | 10:53 AM
mkc70's Avatar
Thanks,
Chet
Blown speakers is a more likely answer. Purchase a Blitzsafe or USAspec iPod adapter to work through the changer connections. Speaker choice is subjective, just buy what sounds good for the music you listen to normally.
Old Sep 9, 2009 | 03:53 PM
boldtu's Avatar
Thanks for the info
I will check to see if I am getting power to the speakers
and get that adapter
Chet
Old Sep 9, 2009 | 05:46 PM
boldtu's Avatar
So I took the stereo out of the dash. I found that the stereo was prewired for a cd changer, or it came with one and was removed. Does anyone know where it was located when stock? I looked under the front seats and in as many places as I could think of in the hatch area and didn't find any RCA wires.
Thanks,
Chet
Old Sep 9, 2009 | 07:36 PM
mkc70's Avatar
Thanks,
Chet
Trunk, driver's side I think.
Old Sep 24, 2009 | 11:14 PM
boldtu's Avatar
OK,
I have everything done but the speakers in the dash and D pillars. I cant find Speakers that fit. Has anyone replaced these things? With what? thanks again guys
Old Sep 25, 2009 | 06:58 AM
gilber33's Avatar
Here's like the stereo bible I found when searching for what to do when replacing speakers and what not. If you have anymore issues this should help you out.
http://www.volvo-forums.com/t21128-s...-850-wagon.htm
Old Sep 25, 2009 | 07:06 AM
Somthngfrce's Avatar
You can also go on to Crutchfield http://www.crutchfield.com/cgi-bin/a...r%2fMyCar.aspx and use their fitting guide and see the peakers that will fit. They stock a ton of stuff for most cars. That's how I got my Boston speakers....
Old Sep 29, 2009 | 05:03 PM
boldtu's Avatar
Thanks that "Bible" was great, and crutchfield is a great resource. I found that the speaker sizes that they state for the 850 are incorrect but they have pretty good prices. Thanks for all of your help.
Chet
Old Oct 5, 2009 | 10:32 PM
vijju's Avatar
Banned
oh take a deep breath, put a meter on the leads in the harness. Find out which one comes on with the key, thats the one that has to be power for the new radio. If you dont have a meter then get a cheap 99 cent 12vdc tester from auto store, will work fine.
Dj Eterno
Jan 30, 2008 07:49 AM
TacklaNHL
Dec 20, 2007 01:55 PM
05S40BE
Oct 25, 2007 11:16 PM
Sven
Jun 19, 2006 09:43 PM
blaackone32
Apr 20, 2005 07:09 PM
