Engine & Internal Chat about beefing up your insides here.
Timing belt bad ?????
Old Oct 20, 2009 | 06:38 PM
rcsron66's Avatar
Default Timing belt bad ?????
I am trying to help get my Grandsons 1995 850 Turbo back to running condition..
I suspect the timing belt is bad..
I need to know the plug wire assignment for the distributor and want tthe spark plugs.. Just want to verify they are correct.
Then I want to check the timing and need to know what the timing specs are.. I want to see where the timing mark is when we are pointing to Number one on the distributor..(PS where is the timing mark?)
Any help to determine if the timing belt is bad would be appreciated..
Then if it is the belt the procedure to replace same...
Old Oct 24, 2009 | 09:36 AM
There is marks on the upper timing belt cover. Then there is lines on the cam pulleys.
If the wires are OEM they are numbered on the plastic wire holder. Also the cap is numbered.
bubbaaj1
Apr 27, 2018 05:45 AM
jmana
1998-2000 model year V70
Feb 16, 2015 07:02 PM
tscarborough
Sep 27, 2012 05:23 AM
ThomTDI
Jan 1, 2011 03:16 PM
Qamar
Aug 24, 2005 07:37 PM
