Volvo 850GLT non turbo 95' Engine Light
Old Apr 16, 2007 | 11:56 PM
silentdeath489's Avatar
Default Volvo 850GLT non turbo 95' Engine Light
Hi, my girlfriends 1995 Volvo 850GLT Non-Turbo has the check engine light on. When i went to get it checked it was P0440 - Evap Emission Control System Malfunction
Does anyone know what I should do? She is tight for money at the moment, and i want to fix this car, if its a sensor or something i can get at under the hood ill do it, but i need to know where to start. I tryed tightning the gas cap already. Thank you.
Old Apr 17, 2007 | 12:15 PM
Psaboic's Avatar
Default RE: Volvo 850GLT non turbo 95' Engine Light
Hi,
I was going to suggest the gas cap as well. The thing is, once the check engine light is on, you have to reset it or it will stay on even if you have fixed the problem. First off, I would take off the gas cap and check the seal to make sure it is not torn or cracked. Then put the cap back on and tighten it until it clicks.
To reset the light, you are forutunate you have a 95 model, as you can reset it without a code scanner. I do not have the procedure in front of me, but you reset it using the diagnostic connector in the engine bay. DO a forum search and you should find it. IF not, simply go to your local AutoZone (or other auto parts store) and ask to rent/borrow their code scanner. You can also use that to reset the light. If after resetting, the light stays off, you are good to go. If not, we can dig into it more.
Good luck,
Glenn
Old Apr 17, 2007 | 01:40 PM
JPN's Avatar
JPN
Hi,
Procedure:
http://volvospeed.com/Repair/a2.html
Anew gas cap is available at AutoZone for a few dollars (Stant).
If the cap doesn't solve the problem, inspect the Evaporative Emissions System in the engine bay. Check for rubber hose connection integrity, cracked hoses, elbows, etc... in the system.
If your GF plans to keep the car for more than a year, I suggest that she/you buy a Haynes service manual (about $15-$20).
Cheers,
JPN
Old Apr 18, 2007 | 09:35 AM
thank you guys its been raining in new york for like 4 days so ill give it a shot as soon as the weather clears up and tell you whats going on.
Thanks
Old Apr 18, 2007 | 09:53 AM
JPN's Avatar
JPN
Hi,
Take your time and let us know how it goes. My friends in Boston told me it's been raining there too.
Good luck,
P.S: If you couldn't save the picsbefore I delete them, ask me and I'll post them again.
JPN
Ablorx
Jul 4, 2014 08:33 PM
Alex11
Jun 2, 2009 04:26 PM
92Typhoon
Jun 10, 2007 06:00 PM
rfa1972
Apr 19, 2007 03:36 AM
92Typhoon
Sep 22, 2006 01:48 AM
