'05 2.5T timing belt instructions
Old Feb 16, 2012 | 06:49 PM
rmcphearson's Avatar
Default '05 2.5T timing belt instructions
I have not been able to find instructions specifically for my '05 S80 2.5T timing belt change. I have 93k on it but I'm not going to push it to 105k. The closest I can find is the Chilton manual for '04 which states for the "5 cylinder" the vibration dampener must be removed with volvo tool # xxxx. Do I really need to remove the dampener?
Roland
Old Feb 16, 2012 | 07:17 PM
Some have changed the belt without removing the dampener.
But I have air tools so I just remove it.
Old Feb 18, 2012 | 11:23 AM
Thanks tech,
I cannot see obvious timing marks. I don't see anything that lines up with anything! Just a 0.. mark on each cam pulley but they don't orient to the top at the same time. And a V mark on the auxillary belt pulley but it's not near the perimeter, it's near the main dampener nut. Well I turned the dampener 1/4 turn CCW per the instructions and I'm making my own marks.
Old Feb 18, 2012 | 05:28 PM
Sometimes the marks can be really really hard to see.
Old Feb 19, 2012 | 07:33 AM
Thanks for checking in on me tech. Sending you a PM. I got it done after making my own marks. I replaced the idler and tensioner as well. All parts were from FCPgroton and the belt was a Continental.
Roland
75ohm
Mar 13, 2017 10:37 AM
bgeacook
Aug 17, 2009 01:26 PM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
