1992 Volvo Winter Mode
Old May 3, 2006 | 11:42 PM
fatduck's Avatar
Default 1992 Volvo Winter Mode
I own a 1992 Volvo 960 with 210,000 miles and plan to keep it running for 2 more years.
My big problem now is some times the mode switch says I'am in winter mode but the car is not in winter mode and after a few minutes it goes back to economy. And it takes about 5 miles on the highway before it will go into converter lockup.
I changed the pnp switch and no difference.
Thanks
Lou Tarullo
Old May 4, 2006 | 08:41 PM
Default RE: 1992 Volvo Winter Mode
What codes are you getting?
Old May 5, 2006 | 12:07 AM
fatduck's Avatar
I will have to check this weekend, never checked for codes before so I will have to spend some time with it.
I will get back as soon as i check.
Thanks
Lou Tarullo
Old May 8, 2006 | 11:30 PM
fatduck's Avatar
I checked the code this weekend, I checked block A pin 1 and I got code 142. Does anyone know what this code is?
Thanks
Lou Tarullo
Old May 9, 2006 | 12:06 AM
If the code 142 is the only code that came up then the trans might be slipping.
That code means the Trans fluid was overheated. Most likely from slipping.
prepg
Jan 21, 2020 06:44 AM
fadam
Oct 16, 2017 06:27 AM
rahaley813
Sep 26, 2011 04:08 AM
cool_kyle_3000
Aug 26, 2008 07:05 PM
tupapison
May 12, 2006 11:26 PM
