1998 V70 stopped running
Old Dec 27, 2012 | 11:13 PM
jrkim's Avatar
Default 1998 V70 stopped running
New to the forum and am not sure what to do. I have a 98 v70 with 130k mileage. I drove it on Sunday with no problem and parked it in my driveway. Today, Thursday, it would not start. When I turned the key the engine turned over but would not start. I charged the battery, almost brand new, checked one of the spark plugs and it is getting a spark. I could smell gas where the plug was. I sprayed starter fluid in the intake, checked the fuses and it still will not start. Any suggestions. I even had the codes scanned and nothing came up.
Any help would be greatly appreciated. I am hoping to pass this car down to my son soon.
Old Dec 28, 2012 | 03:31 AM
A car needs 4 things to start and run; air, fuel, spark, and compression.
The most common problems are
1. Bad fuel pump relay.
2. Bad or low compression due to a burnt valve or some strange compression issue.
3. Broken timing belt.
Is the timing belt in tack?
Old Jan 11, 2013 | 12:08 AM
gdog's Avatar
Also might get more hits in V70 section..
Some background info would also be helpful; i.e. do you have mechanical/automotive experience, whether professional or DIYer, do you have tools, etc. etc...
egm8599
Aug 25, 2010 05:50 PM
svenska
Mar 31, 2009 02:41 PM
gridlockfilms
Nov 26, 2007 11:49 PM
gridlockfilms
Nov 26, 2007 07:22 PM
xps
Apr 27, 2007 12:33 PM
