2000 S40, turn Signals not working
Old Nov 20, 2010 | 02:03 PM
hobbitwho's Avatar
Default 2000 S40, turn Signals not working
My turn signals are not working but my Hazards do. I have replaced the Flasher but did not make any difference. The Cruise Control works (Located on the turn signal arm). I have tested the Fuses (Both Panels) and all are working properly.
I am thinking the Turn Signal Arm is not working (Broke internally).
The car was in a Front End Collision but not bad, it bent the hood and the Radiator Support 3/8 of an inch.
Does anyone have any idea?
Additional Information: There is also another problem, not sure it is related. The Internal Lights are not working, I have replaced the Fuse twice and when I do, the lights work and the engine runs much better but when the fuse burns out, the lights stop working and I get a check engine light (FLASHING)....
Last edited by hobbitwho; Nov 22, 2010 at 08:31 AM. Reason: Additional Information
Old Nov 21, 2010 | 06:55 AM
ibanez958's Avatar
is the turn signal working at all, or intermittent?? if so check the relay
Old Nov 22, 2010 | 08:27 AM
hobbitwho's Avatar
The TURN SIGNALS DO NOT WORK AT ALL, the Relay (Flasher) was replaced but no change. The Hazards work perfectly. I also have a Check Engine Light that FLASHES and the Internal lights are out and the Door Ajar light is on.
hu5ker555
Jul 12, 2013 08:59 AM
'88volvo240DLdriver
May 28, 2012 07:56 PM
efatsi
Mar 16, 2010 02:46 AM
Ked
Nov 9, 2009 09:27 PM
